Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 882s or 193s... HELP!
Old 09-18-2008, 01:57 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Senior Curmudgeon
Wiki Edits: 326
I'd be more inclined to use the lower c.r. if you don't plan to optimize the squish by either cutting the decks or changing pistons. With a wide squish, you may encounter detonation with the higher c.r. on pump gas. I'm not sayin' it WILL ping, just that it will be more likely to.
