89 2500 with a t-400 , no 2nd 3rd gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2008, 12:42 PM
im working on my friends 89 2500 with a th 400 and he said he said he got off the freeway and it started smoking from under the car and then he lost 2nd and 3rd gear did not try to mauaully shift it but he drove it home 4 miles and park it i pulled the pan off and the fluid was burnt but no metel whatsoever in the pan and it was rebuilt a year before oh yh the fillter was broke when i took the pan off too any help would be great thanks
Old 02-02-2008, 03:09 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
calhoun... I edited the thread title from " Help , need help".. We know you need some help with a problem if you post here.
You say the filter was broke. The t-400 filter is metal. Are you talking of the plastic type tube between the filter and trans case?
IF that was broken , I wonder If the trans was sucking some air and burned up the frictions?
I would open the filter up and see what is inside of it for a start.
good luck , post back when you can.
Old 02-02-2008, 11:55 PM
yes the plastic tube is what i ment
Old 02-04-2008, 08:40 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
To answer your PM;
I do not know if the trans is smoked.
Did you :
open the filter? Was it full of debris or clean?
Did you replace the filter tube & filter , fill the trans with fluid, test drive? Did it shift?
Check the governor for a broken / melted plastic drive gear? It is under the steel - square shaped cover with 4 bolts.
have you checked the vacuum at the modulator? Is the hose OK? Is there vacuum there as the engine runs?
Let us know
400 searching for gear price Transmission - Rearend 1 07-18-2007 11:17 AM
no 2nd or 3rd gear sik400 Transmission - Rearend 7 07-17-2007 10:14 AM
700R4 sticking in 2nd gear chrisape Transmission - Rearend 6 01-04-2007 05:01 PM
89 chevy 1/2 ton 5-speed truck gear oil??? tiresmoke55 Transmission - Rearend 12 09-12-2006 10:46 PM
700R4 will not shift into 3rd and 4th gear bebopwally Transmission - Rearend 14 05-25-2006 07:48 PM
