89 c1500 brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2010, 11:28 AM
runn141's Avatar
89 c1500 brakes
i have an 89 Chevy c1500 2wd pickup. i bleed the brakes and cant get no pedal, so i put new calipers and pads on the front and bleed them and still no brakes. so i change the master cylinder, same thing. there are no leaks and no air in the lines that i can get out. Ive even replaced the proportioning valve and the dump valve.
Old 11-24-2010, 02:05 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Did you bleed all 4-wheels or just the front ? Go back fill the M/C with fluid and go to the passenger rear wheel and bleed it first after you have it done move to the driver side rear and bleed it, When done there go to the right front and bleed it and then to the left front. And what ever you do never let the M/C run out of fluid or then you have to do it all again. After you get the air all out check the pedal and if still not happy then check the adjustment on the rear drums they might need a little adjustment also.JMO
Cole
Old 11-24-2010, 02:28 PM
runn141's Avatar
ive done exactly that in that order. and the only brakes that will lock up on dry pavement are the back. and the pedal still goes to about an inch from the floor.
Old 11-24-2010, 02:29 PM
eloc431962's Avatar
Wiki Edits: 37
Sounds to me like you might have got a bad M/C it does happen.
Cole
Old 11-24-2010, 02:41 PM
Onefunponcho's Avatar
When you were changing the prop valve,or master cyl did you accidentaly crimp smash or twist any of the steel lines? Or were they plugged with dirt or filth when they were off?
First thing I would do is give the system a good flush at all four corners to make sure its all moving correctly. If it is, Then give it a good bleed with fresh fluid and you should be okay.
Old 11-24-2010, 02:50 PM
T-bucket23's Avatar
Wiki Edits: 26
You swapped teh front calipers, did you put them on the correct sides, this is a common mistake. The bleeder must be at the top.
Sometimes on those trucks it is helpful to just open the bleeders and fill the master and let it gravity bleed for a while (until you see fluid).
Chet
Old 11-24-2010, 02:54 PM
eloc431962's Avatar
Wiki Edits: 37
Chet you read my mind , I was just thinking about the same thing about the calipers being on the right sides, And i gravity bleed my brakes just about everytime. Always works for me well most every time.
Cole
Old 11-24-2010, 03:45 PM
runn141's Avatar
Cole
i had bought 2 new M/C, both were bad. so i got a used one from a friend's truck that i know had brakes.
Old 11-24-2010, 03:48 PM
runn141's Avatar
i have them on with the bleeders at the top. and im letting it gravity bleed at this moment and no lines are crimped. how many bowls of brake fluid should i let run through it?
Old 11-24-2010, 03:53 PM
eloc431962's Avatar
Wiki Edits: 37
Just let it bleed down about 1/4 in or so to make sure all the air is out. Are you trying to gravity bleed one at a time or all four ? I usually do one at a time. JMO You can let it bleed down as far as you want to be satisfied that the air is out thats up to you just keep a eye on it and don't let it go dry on you.
Cole
Old 11-25-2010, 08:15 AM
runn141's Avatar
i had bought a used M/C from a truck that i know had brakes. i got it and the dump valve and proportioning valve all together. my dad put it on and he didnt bleed the M/C because we never took the lines loose from it to the proportioning valve. should we do that? he says no. now he argues that its the booster not getting enough vacuum. i always thought that if it went bad the pedal would be hard to push. then he says it may be electrical(i dont see how) unless its from the module that wires from the dump valve are going to. what is the dump valve? i see a bleeder on it. we have bought so many new parts for this truck, its to far to turn back and junk it.
Old 11-25-2010, 08:31 AM
eloc431962's Avatar
Wiki Edits: 37
Here click the link and read where it says pedal problems. http://www.aa1car.com/library/abs_kelseyhayes_rwal.htm .
Cole
Old 11-25-2010, 11:04 AM
runn141's Avatar
Cole
after reading that i think im gonna do away with the dump valve and just bypass it. if i can get a coupling from a 5/16 line to a 1/4. ive had trouble with wiring on this truck anyhow so i figure thats the problem.
Old 11-25-2010, 10:29 PM
If the dump valve is stuck open you won't have any pressure to the rear wheels. Silly question but are the rear brakes adjusted up enough so they drag a little when your turning them by hand?
These trucks never did have a great feeling pedal but they stop OK not great. If you do away with the RWABS the pedal will come up a little.
Have you bled the dump valve as well?
Old 11-26-2010, 11:32 AM
runn141's Avatar
the rear brakes are adjusted, i had them working once before but that was all that was working.
i put new pads and calipers on the front.
i have had 3 M/C on it.
i have changed the proportioning valve.
i have done completely away witht the dump valve.
i have no leaks anywhere.
i have gravity bled.
i have bled them manually.
i get no air coming out of the lines.
and still no pedal or brakes to stop it in gear. the pedal still goes to about an inch from the floor. what do i have left to do???
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 10 01-24-2011 11:09 AM
Manual disc brakes galaxieguy3 Suspension - Brakes - Steering 6 07-21-2009 06:49 PM
Need Help With My Brakes S10 Racer Suspension - Brakes - Steering 4 01-18-2009 02:00 PM
poor power brakes with 7'' booster TheCiscoKid Suspension - Brakes - Steering 6 11-12-2008 10:51 PM
Lowering my 89 Chevy C1500 bcf15 Suspension - Brakes - Steering 4 12-24-2003 04:57 AM
