89 chevy p/u,98 cheyv p/u swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2005, 07:05 PM
89-chevy-p/u-y350's Avatar
David Carr
i have a 89 chevy 1/2 ton p/u, im wanting to put a dash out of a 98 in my truck...im not sure what year they started changing the dash but i like it better then the 89 style...i have done some researching and found that a lot of stuff is the same...grill...the body is all the same from what i can tell...i need to know if anyone else has done any research and found out anything..and if there is anything else i can do to my chevy to customize it..thanks...
Old 06-02-2005, 10:26 AM
jalopy45's Avatar
After you pull all the trim and as you can off the donor dash off you'll have the same piece of bare metal staring at you. Mounting holes should all be there and make sure to grab as many of the screw clips off the donor dash as you always lose them and are 1 short in the end.
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
Old 06-03-2005, 10:15 AM
mikev's Avatar
New Member
I think they changed the interior around 94 or 95. Almost all of the body and interior parts can be interchanged to include that body style escalade. Check out www.gmfullsize.com or www.fullsizechevy.com . These guys are dedicated to the trucks.
Old 06-08-2005, 06:45 PM
David Carr
hey, thanks for the sites..they are pretty nice..i joined the forums...does anyone know of anything else i can do to change my truck a lil bit....im wanting to do a lot but i dont know what to do or what i can do...im wanting to do some fiberglass work but know nothing about that and it pretty expensive around here to have ANYTHING at all done..thanks..
Old 06-10-2005, 02:47 PM
GothRod87
fiberglass is pretty much a straighforward learn as you go experience...i just recently tried doing it cause i have alot of interior plastic panels that are nasty and scraxched up badly..i was wanting to do it cause of how smooth it makes it and its ALOT better to paint glass then it is to try painting the normal surface, a good site to learn alot about glassin is www.minitruckzone.com ...just join the site its free and read up everything and be glassing in no time,hope it helps,
GOTH
Old 06-13-2005, 12:11 PM
David Carr
hey, thanks for the site, i will have to check it out one day...i am at work on my lunch break and dont want to use their computers to much, and i h\dont know what all i can do on here..but i will check it out one night when i get home..anyone else know of anything i can do to my truck???im thinking about the led blinkers in my mirros.
1953 chevy frame swap Bwagner General Rodding Tech 3 07-01-2004 09:35 AM
40 Chevy P/U caddymanwi Hotrodders' Lounge 0 05-24-2004 02:11 PM
1965 Skylark Chevy Swap 65skylark Engine 0 05-24-2004 01:23 PM
Chevy 305 manifold swap 87442lover Engine 5 03-03-2004 04:52 PM
pontiac V6 to chevy V8 swap snake Engine 2 01-20-2002 04:58 PM
