89 Chevy P.U. TBI ????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2002, 12:52 PM
New Member
Post 89 Chevy P.U. TBI ?????
My truck is a 89 chevy with a 350 engine with TBI. I have a engine from my other car that runs really good that I want to swap to my truck. It's a 350 .030 over with 305 heads,somewhat flattop pistons.Med. cam. It is carb. I.ve changed the heads useing later model 305's (a little less Comp.)and from a tbi engine.My ques. is: Will the TBI work and perform as well as the carb. or will I have to go too larger mm injectors. Is there larger injecters for my TBI?
Old 11-12-2002, 02:52 PM
Post
hey you stole my motor-j/k. it works as long as you have a 350ci chip in the ecm and not the 305 chip. but the carb will do beter unless you have someone like JET make you a chip. but make sure their is good map pressure or the thing a run like poo. im sure it will since youll be using the lesser flowing heads. when i did that sort of build up i later ditched the TBI for a quadrajet. mde it alot easier to dial in everything. in my personal opinion-TBI sux.
