89 chevy trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-19-2011, 10:50 AM
89 chevy trans
I just bought 1 ton 89 chevy . It doesn't shift into high gear until 60mph and it drops back to 2nd if you drop below 55. I put a new vac. mod. and it does seem to have vac pressure
Old 07-19-2011, 01:50 PM
And that would be the problem. If the vac line to the modulator isn't providing full manifold vacuum at the trans, the trans will not shift correctly.
Old 07-23-2011, 05:48 PM
chevy trans
modulator didnt help. I checked the electric kick down (no power at idle) so that should be ok. then I removed shift gov. cleaned it the pston in the middle seemed to be moving up and down when the weights were moved in and out.
chevy 396 into 79 trans am retrota79 Engine 29 10-29-2010 05:24 AM
Putting a 72' chevy 350 into 1995 chevy silverado that has a 4l80e trans Willbee26 Transmission - Rearend 3 03-28-2010 11:40 PM
BB chevy into 79 trans am retrota79 Engine 11 04-18-2009 12:13 PM
Chevy engine doesn't fit Chevy Trans! 2000jack Engine 21 01-31-2008 11:51 AM
Chevy 350 Engine & Trans in a 46 Chevy Pickup Warner Engine 4 02-11-2005 05:44 PM
