Originally Posted by latech
What are the system pressures? and at what daytime temperature are you working in. Also how much R 134 a did you put in.
Dont get carried away with the oil charge either. Answer please.
Dont look for a sight glass, your system is a GM CCOT and they have a accumulator not a reciever /dehydrator...so no sight glass.
Yeah this is a red neck operation 75-85 degree I have know gauges yet. I just added a 134a retro fit kit with the fill gauge! Got the right lines from the compressor to the condenser replaced one of the valves on the low pressure side service port but could not replace the high pressure side it has a bigger valve stem! I could not get it out but its not leaking so I left it a lone and cleaned the condenser! So I used a oil and 134a recharge kit to fill the system!
The lower line that runs from the condenser to the evaporator is cool has oil in it. Accumulator is room temp So that's where I'm at!
OH! Last the motor that's in the truck is a 350 out of what I think is a 94 truck so its not the stock compressor for 89! other than that everything is stock!
I can put up a picture if needed
Craig
