89 cougar 7.5 rear diff. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2006, 09:27 AM
has anyone put one of these in a hot rod? Recently aquired a complete rear differential assy.,coils,complete axel assy, and rear frame work out of a 89 cougar. Rear diff has 7.5 cast on top. Looks like it would be cool in a hod rod. Anyone know how much power these will take? Any number code to tell if posi, or gear ratio? Will be behind slightly pumped 302, and 4 speed. Any help will be appreciated. Thanks.
Old 04-06-2006, 12:33 AM
tbirdscott's Avatar
stuff'n things'n whatnot
If you use it be gentle, they dont take kindly to much over 200hp and soft driving. Its very unlikely it has tracloc
Old 04-14-2006, 10:16 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Mustang GTs used the same rear end through about 86 when FORD upgraded to the 8.8. A 7.5 is not real strong, but it will depend on how much traction you have and how abusive you are with that clutch.
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 09:03 AM
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 07:10 PM
"Bowed" deck lid cruzinTLT Body - Exterior 3 03-04-2005 09:24 PM
can i put 8.5 into 7.5 rear end houseing bradsregal85 Transmission - Rearend 2 02-25-2003 06:11 PM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 10:50 PM
