89 F250 5.8L MFI, rough surging idle (Code 23) - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2011, 09:40 AM
mike 96 ws6's Avatar
old dog learning new tricks
It runs down the road fine but the idle is not very smooth. Not a dead miss but the exhaust note is not constant (more like the sound of an aftermarket high lift/long duration cam). The exhaust does not smell rich. Sometimes when idling in gear with A/C on, the RPM surge will get to the point where it will go dead.
I installed new plugs and wires yesterday. (no plugs were fouled but all 8 were pretty white from running lean).
I did find some leaking vacuum lines and fixed them. How do I check for a leaking EGR valve on this truck? (EGR is solenoid controlled, not vacuum controlled / very limited access to try to lift the pintle manually).
How do I diagnose code 23?
I can't tell if TPS is adjustable or not (not very accessible on this MFI arrangement).
Thanks for any help!
Mike
Old 07-20-2011, 01:48 PM
DoubleVision's Avatar
How many miles are on this engine? If the mileage is high, grab ahold of the throttle and see if it will shake. If it moves it`s worn out from high miles and when the throttle closes it closes at a different place everytime from wear and it`s making the TPS read way off, now you know why it won`t idle.
Old 07-20-2011, 02:03 PM
Joe G's Avatar
Sounds like it could be a sticky Idle Air Control Valve. It would be simple and cheap to pull it off and clean it.
Good luck....
Old 07-20-2011, 02:44 PM
RippinRon's Avatar
Code 23 is tps out of range. A new aftermarket one may be slotted for adjustment but the stock is not.
Old 07-20-2011, 03:05 PM
Thanks guy's!!!
Got it running pretty smooth.
Disassembled throttle body and cleaned IAC motor, throttle plates, and adjusted TPS to 0.470 at closed throttle (was 1.670). (hope it stays there. I saw no slack in the throttle plate bushings?).
Thanks for the help everyone!!!
Mike
Rough idle, high idle in park, stalls in gear.. Help! ratmaro Engine 16 03-23-2012 05:29 PM
surging idle bradykat Engine 1 06-06-2010 01:28 PM
1981 Gm 3.6 V6 Rough Idle And High Idle nomaddaddy Engine 1 11-15-2007 09:49 PM
Rough idle Yub350 Engine 1 12-07-2004 01:06 PM
Seeking advice on rough idle; "Y" code 307.. Oldsmolac911 Engine 1 11-14-2002 12:25 AM
