Thread Tools Search this Thread share on Facebook
  #1
Old 03-30-2009, 06:03 PM
chevy_c10 chevy_c10 is offline
89 Ford Ranger No Start
Hi everyone. I have a question regarding an 89 ford ranger that has a no start condition. We are working on it up at our local college and have almost come to a dead end. There is spark, fuel pressure is in spec, and there is compression. However, there is something in the circuit that has to do with grounding the injectors. I know this since we have checked for power at the injectors and sure enough, it is there. When the injector ground wire at the ecm is connected straight to ground, the noid light comes on. It seems that our only problem is the lack of the injectors pulsing. My question is this, does the DIS module control injector pulse on fords like on chevys? We have checked all the wires that should be "inputs" to the DIS module. However, we are unaware of which wires are "outputs" and do any of those outputs return to the ecm? If anyone has any tests numbers (in terms of volts, ohms, etc) it would be greatly appreciated. By the way, we do not have access to a break out box.
Register now (free) or login to remove ads
Old 03-31-2009, 06:21 AM
barnym17 barnym17 is offline
Go to Auto zones web site and sign up for alldata for that vehicle it will give you the info needed.
Old 03-31-2009, 10:11 AM
matt167 matt167 is offline
Wiki Edits: 31
what engine does it have? is it the DIS 2.3 4cyl?
if the crank sensor or cam sensor is bad, it won't pulse.. if it's got the distributor, the TFI modual could be bad as the distributor does act as the cam sensor.. the distributorless 4cyl would have a bad cam sensor, but they had both versions in '89, seems it was a crossover year
Old 03-31-2009, 12:19 PM
It is the 2.3 DIS. However, would there be spark if the crankshaft sensor was bad?
Old 03-31-2009, 12:35 PM
sbchevfreak's Avatar
sbchevfreak sbchevfreak is offline
Licenced Automotive Technician
There should be a small ground wire from the negative battery terminal, that goes to a single cavity wire connector. If this ground is bad, the processor will not work, and cause similar issues. This was a common ford issue of that era.
Old 04-07-2009, 10:05 PM
I just wanted to post back and let everyone know that a new ecm fixed the problem. Thank you all for your help.
Old 04-08-2009, 10:19 PM
Thanks for the update!
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "89 Ford Ranger No Start"
ThreadThread StarterForumRepliesLast Post
36 Ford Pickup on a Ford Ranger Frame?FasteddyGeneral Rodding Tech2011-29-2010 08:53 PM
Ford Ranger manual steering box ?AC/DCSuspension - Brakes - Steering1208-12-2006 06:41 AM
SBC into 88 Ford Ranger Ext. CabKenny13z3Engine105-28-2005 07:20 AM
Whatever happend to these guys?hot_rod_kidHotrodders' Lounge2012-17-2002 09:20 AM
2001 ford pick up wont start rightClintonHotrodders' Lounge307-10-2002 04:25 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
