'89 Nissan Hardbody Low RPM Engine Knock - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2012, 06:17 PM
In my 1989 Nissan D21 147000mi, During any drive time, when I take my foot off the accelerator, I hear a bottom end rapid knocking sound that gradually stops. I checked timing chain, and oil is good. Any suggestions?
Old 02-15-2012, 07:53 AM
Last journal entry: Still running strong
I would think that if it was a knocking rod it would knock at any rpm.But with that many miles on it,it could be the beginning of a rocking nod.Maybe at a higher rpm your oil pressure is higher an helps to straighten out the rod.One way to check is to use a long screw driver put it against the bottom of the engine block,other end against your ear and you can hear if its knocking. My dad taught me that trick. Rocking nod mmmmmm.
Old 02-15-2012, 12:06 PM
Good idea. But I forgot to mention that I've done that already with my stethescope. The knocking is almost non existent until I drive it.
Old 02-15-2012, 01:20 PM
Actually its not really a knocking sound. More like a rattle.
1983 Nissan 720 4x4 2.4L NAPZ engine knock ViperMonster800 Engine 2 12-03-2008 11:23 PM
swap a 454 into a 89 nissan hardbody str8blazed661 General Rodding Tech 6 08-19-2007 10:05 PM
install a 454 in my 89 hardbody str8blazed661 Hotrodders Site Suggestions and Help 1 08-19-2007 02:17 AM
Lowering a nissan hardbody to lay pavement goth_rod87 Suspension - Brakes - Steering 2 09-18-2005 11:14 AM
New Nissan engine???? Super Streeter Engine 3 06-05-2004 11:28 PM
