89 S10 wiring problem...... HELP!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2010, 09:55 PM
Jeffs10's Avatar
I need help!!!
1989 s-10 with a 4.3 (not original engine) was a 2.3 I bought it for $700 bucks and the 4.3 swap was already done. Anyway here we go
I pulled out the throttle body and the stock intake.
I replaced with Holly 4160 600cfm and Edelbrock performer intake. Install is done now.
I also yanked out the Air conditioner.
I also installed a Mr. Gasket mini fuel pump.
And replaced the old stock distributer with a vacuum advance distrib with the in cap coil.
This is my problem.
Im fishing around for hot wires to hook everything up.
I have the original coil hotwire hooked up to the new distributor so Im good there I THINK.
Now I need a good hot wire for the electric choke and the fuel pump.
Also I hooked it all up and got it to start but the timing was off and back firing was bad.
After a real loud backfire from the carburetor it seems the linkage is loose and when you press the gas it wont return rite. Did the back fire damage the carb? HELP
My e-mail is glazelab1@yahoo.com if anyone wants to help with my issues.
Old 08-02-2010, 08:32 PM
No a backfire cannothurt your carb, however, Sometimes a backfire can blow off Vacum lines, makin the engine SLOWLY idle down, AND not all the way down.... Give it a look....
Build up my 350SB for my 89 S10 Amateur Hotrodding Basics 1 02-04-2010 03:42 PM
ron francis wiring problem ScottRods2945 Electrical 8 01-02-2009 02:52 PM
S10 problem 1981monte Engine 6 10-21-2007 08:54 AM
wiring problem vic molina Electrical 4 07-19-2007 07:05 AM
'89 IROC wiring problem jmtw Electrical 8 12-31-2004 01:48 PM
