89 T-bird Rack & Pinion question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2012, 12:30 PM
solidaxel's Avatar
Last journal entry: Project garage complete!
OK, I installed a new (rebuilt) R&P on my Mll to replace a leaking seal on the input shaft, and the new rack acts like i have the input and return hose transposed!!
I have the pressure hose going to the port that is closes to the steering wheel, and the return on the one to the front of the truck, just like the one I removed!
The steering wheel acts like they(hoses) are reversed when the engine is started and a signal is placed on the wheel.
I did bleed the Rack before I hooked up the return line and all was clear. is there something else i should be doing?
I have had this happen before but I did not have a pattern to follow so I reversed the hoses and all was good on the last project.
Are all r&P Fords, built the same way?
Is there a possibility that the R&P was assembled incorrectly, or will they only go together one way?
I thought i would ask questions before I dis assembled the R&P, which i have to remove it to change the hoses around, plus I think the return and pressure fittings (EARLS) will only fit the way i have them.
I could get new fittings tomorrow if that is the problem!!
Old 10-07-2012, 01:03 PM
Wiki Edits: 27
high pressure Bird
I have read that some of the T bird Racks use a higher pressure P/S pump than mustang II, that a stock "GM pump works with out the pressuer reduction modification,
Old 10-07-2012, 01:26 PM
solidaxel's Avatar
The Saganaw pump is a stock GM unit with NO modifications, and the only mods on the rack are extenders, which i removed from the old unit
Old 10-08-2012, 11:43 PM
Pressure to the front fitting, return at the rear fitting.
The Following User Says Thank You to enjenjo For This Useful Post:
solidaxel (10-09-2012)
Old 10-09-2012, 04:41 AM
solidaxel's Avatar
Thanks that is different than the one I removed
I changed them around with different fittings and all works,
Different brands of racks are not all built the same!
Small fitting = high pressure !!
RACK & PINION AFB Suspension - Brakes - Steering 9 12-13-2011 09:13 PM
rack & pinion tmcquaw Suspension - Brakes - Steering 0 04-07-2011 03:29 AM
connecting ps pump to t-bird rack/pinion jbinwa Suspension - Brakes - Steering 2 05-06-2007 11:41 PM
Rack & Pinion 53 5WNDO Suspension - Brakes - Steering 2 03-28-2007 01:44 PM
rack&pinion bighotroddin Suspension - Brakes - Steering 1 09-05-2003 11:33 AM
