Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 89 Throttle body 350 rough idle and hesitation
Old 02-04-2012, 09:46 PM
stich626's Avatar
stich626 stich626 is offline
Last journal entry: The TwoTonShu #10
sometime the tbi throttle shafts wear and cause vacuum leaks
also have you checked the tps.. ? hows the spray pattern out the injectors
egr could be acting up..
just because a sensor was replaced don't mean it can't be failing
check for vacuum leaks, cracked hoses /etc
play in the tbi throttle shaft..
smooth signal from the tps. as it travels from open to closed
