Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 89 Throttle body 350 rough idle and hesitation
Old 02-05-2012, 04:31 PM
LATECH's Avatar
LATECH LATECH is offline
Last journal entry: New Gas Tank
The Oil pressure switch in the back by the distributor has the fuel pump switch and also has the ground path for the Oil pressure gauge.It should have a 3 wire.It may have a 2 wire which would be for the pump and could have a seperate bulb down by the oil fiter for the gauge but I doubt it.
