89 trans am torque arm problem! - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2011, 05:58 PM
BigRoy1978's Avatar
Ok, going to put a torque arm back into this car, 89 trans am. When i took it out the rear end decided to slip, and the rear end yoke is pointing up tword the floor too much for the bolt holes in the torque arm is lined up.
My question, how can i get the front of the rear end pointed down enough so i can get the bolts in? Any thoughts are welcome!
Old 01-04-2011, 06:06 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
scissor jack
Old 01-04-2011, 06:21 PM
BigRoy1978's Avatar
THAT! is an exellent idea!
I tried a bottle jack...but the 54 ton air over pnumatic I have wouldnt fit....it wouldnt hardly fit under the car either....
Old 01-06-2011, 12:31 PM
RippinRon's Avatar
Jack the car up so the rear end is hanging and give it a twist.
Old 01-06-2011, 12:41 PM
BigRoy1978's Avatar
Tried that, ended up using a scissor jack wedged between the car and the rear end to push it down enough to get a bolt in. Thanks all!
Old 01-06-2011, 01:42 PM
malc's Avatar
Living At The Speed Of Life
Did you think you could run the car without it ?
Old 01-06-2011, 02:31 PM
BigRoy1978's Avatar
lol, not that dumb!
too it out cause we were going to pull the trans, but the friend that owned the car decided to part ways with it instead.
...although...a sixth coil/pullbar system WOULD be an answer to this style of rear susp. wheel hop issues! ...if only i had the time.
C4 Bellhousing to trans torque? BT74 Transmission - Rearend 2 09-05-2008 02:47 PM
77 trans am 400 main bolt torque. formula7394 Engine 1 12-28-2007 09:49 AM
1982 Trans Am W/ BW T 10 - using torque arm Trans Am Tony Transmission - Rearend 1 04-23-2007 06:39 PM
Rear end for 700ftlb torque on 79 trans am hallowedpunk Transmission - Rearend 6 02-07-2007 02:04 PM
727 Torque Flight trans problems Steves66 Transmission - Rearend 5 06-30-2006 04:11 AM
