8ba ford flathead engine rebuild - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2013, 10:56 AM
i have a 1953 8ba ford/merc flathead engine that im rebuilding and i got the block back from the machine shop last week and ive been trying to get the rust out of the water jackets and oil gallies with pipe cleaners we got the motor out of the woods so its pretty rusty does anyone know anyother waysd to clean them out?
Old 01-26-2013, 03:30 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Acid will do it, but that's not something you'd want to do if it's already been machined.
If the rust wasn't that bad you could use a strong radiator flush after the engine is running.
If you're adventuresome, try doing it w/electrolysis: Rust Removal.
Old 01-26-2013, 05:48 PM
BOBCRMAN@aol.com's Avatar
I used to send them out to be dipped at a rust removal place. But the government has forced all the alkaline dip guys out.
Old 01-26-2013, 09:30 PM
Wiki Edits: 27
one more business closed
The guy I used to go to said it would cost over a million dollars to make his shop comply with the regulations, and it would take about 150 years to get his return on investment. I ran across one guy who was still doing a few on his farm and when I said no secondary containment he got real nervous, I just said it;s your drinking water supply you are messing with if it leaks.
Old 01-27-2013, 06:55 AM
I did see a mention about a month ago about an Australian company selling a non acidic cooling system cleaner. It mentioned working by a process called chelation.
That means using molasses.
About a 7 part water to one part molasses solution will slowly remove rust. But it need to be warm to work.
I would not use muratic acid. That is just another name for hydrochloric acid.
8ba Flathead oil pressure question belvydeuce Hotrodding Basics 3 08-05-2009 09:41 AM
Ford Flathead 8ba to a 34 Ford Trans. Nailheadforty Transmission - Rearend 2 05-13-2007 07:31 PM
8BA flathead oil pan cleanout plate powerrodsmike Engine 0 09-13-2005 04:52 AM
SROD trans behind a Flathead 8BA Hotrod Hirning Transmission - Rearend 2 10-20-2004 04:21 PM
What is a 48 to 53 8BA Flathead worth? levis classic Engine 1 07-02-2003 11:24 AM
