8V92 Redline? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2007, 07:50 AM
350c10
8V92 Redline?
I know this isnt really a hot rod engine but Im hoping someone here knows where the governer is supposed to kick in on these engines. Much less the rpm range where excessive wear comes into play. I have driver running these engines at 2175 rpm steadily. I know detroits especially the 2 strokes are rev happy but wheres the point where its too much for these engines?
Old 02-27-2007, 08:25 AM
bondo's Avatar
I believe you'll find the Powerband on those is 1600 to 2200rpms......
Fuel Economy is at about 1800rpms.....
2400 is about the Max upper limit.......
Old 02-27-2007, 08:29 AM
seriousracer's Avatar
be a man dodge tree bark!
holy crap 2175!
maybe i was goofy but i only ran the one i had in an old ford tractor to 1850.
and than an old timer told me that was on the edge. 2100 to for shift point in low gears. is this a big 500hp motor.
the new cummins i was running would run at 2750 making 350 hp. in a streight truck of 26k gvw.
what are you guys doing about the low sulfer fuels? the reason i got rid of my dismel....two lift pump later and o rings leaking...
Old 02-27-2007, 08:36 AM
350c10
Low sulfer? Yeah right the engine is running avionics grade deisel (JP8). I know its bad for it but we can only run what we got. The driver I am conerened about has already blown the oil and compression rings on a brand new 8v92. Its a (80,000 dollar engine). Im concerned about having to replace another one. Itll make 2 in 6 monthes. The actual enging model is 8V92TA. Its alot of money and alot of work to install this equipment into a M1075 PLS() Paletized Loading System.
Old 02-27-2007, 09:15 AM
2100 rpm is the rated maximum speed on these engines,and if the governor is set correctly don't worry about it they will go several hundred thousand miles at this rating.A bigger problem is probably the oil type assuming since it a palletized load system you are in the army, correct? 15/40 does not work well in these engines make sure you are using straight grade 30 or 40 wt.
Old 02-27-2007, 09:24 AM
8V92 redline
Call your Detroit dealer for the info; if you're using electronic controls (DDEC), order a DDR and it'll tell you everything. There's also a laptop version available now. I'm not sure but you might be able to set the max engine speed wherever you want. If nothing else you can have an ECU remapped to the specs you like, generally expensive but less than 80K for a new engine, and imagine the grumbling when your driver can't drive it over 1500 rpm.
The Coast Guard uses 6V92TA in our 47' Motor Life Boats with the DDEC III system. We get 435hp in the 2100 to 2200 rpm range. We generally cruise around 1850-1950, mostly to conserve the engine life and keep the engine room temp down.
If you're worried about running the aviation fuel through your injectors you can ask Detroit about mixing some 30wt oil with your fuel. We used to do that on the cutters when running JP5 through the diesels in Alaska. While JP5 does burn good and keep the cylinders clean, it doesn't have the lubrication properties of diesel and your injectors can seize up. They may also have retrofit injectors that work with JP8.
Old 02-27-2007, 09:42 AM
350c10
So these engines will do fine at 2175 rpm running JP8 at an altitude of 8000 feet?
Old 02-27-2007, 10:02 AM
wow boy did you leave out some details....
lol
jp8 at 8000 feet ... i will leave this to some one else who knows i was going on a tractor i used about 6 years ago.....and what pro.. driver told me.
thanks
kurt
Old 02-27-2007, 10:13 AM
re: 8V92 Redline?
If you're using the DDEC system it shouldn't be a problem, it compensates for altitude just like a newer vehicle. You still might want to contact Detroit about running at that altitude to see if they have any concerns or pointers. At that altitude they may recommend a larger turbo, any higher up and you could probably call NASA for assistance.
Here's a link for their service locator: http://www.detroitdiesel.com/Service_Locator/
Hopefully they can help.
Old 02-27-2007, 10:17 AM
350c10
Yeah base mountains for the himalaya's (hundu kush range), and yes this truck is running the ddec 3 ecm.
Old 02-27-2007, 10:27 AM
re: 8V92 Redline?
If you want I can relay your info to my local dealer and see if he can find out anything, maybe he can get the email address for a goverment sales tech rep. Running at that altitude you might need your ECM's remapped.
When you said 8000ft, I figured you were somewhere around Mt Everest.
Old 02-27-2007, 10:36 AM
350c10
We dont have a ddr and itd take monthes to get one. Im just trying to figure out wether I should slap the driver around for abusing our epuipment. Its not easy to get parts.
Old 02-27-2007, 11:45 AM
re: 8V92 Redline?
While they are operating the equipment inside of parameters, slapping the drivers around can still be very stress relieving.
I did contact my local dealer. He says in your situation the high speed/high load conditions are better to keep the exhaust temps up. Excessive idling is the best way to kill a diesel.
If you're wet stacking (over fueling) at your location, you can down size your injectors. He also said that running the JP fuels shouldn't be a problem. Apparently alot of the airport equipment uses JP fuels.
I also asked about the DDR. It's running about $1500, the newest laptop version is $1800 without the cables (or computer).
Good luck and watch that first step, you'd probably bounce all the way to China. (Which by the way seems to be your closest Detroit dealer)
redline meszues Engine 1 09-15-2004 07:36 PM
redline for a 460 ford? Trav Engine 1 02-02-2004 07:37 PM
People W/ 289 Engines Please Help With Redline Question 1967stang Engine 1 10-24-2003 06:52 AM
Raising the Redline Hollywooding Engine 23 07-17-2003 10:19 AM
Redline Oil bluesman123 Engine 9 06-29-2003 09:53 PM
