Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 9 3/8 lincoln diff in 9" housing.
Old 10-27-2012, 07:04 AM
big gear head's Avatar
big gear head big gear head is offline
High Performance Rear Ends
Yes, that is correct. You need to cut clearance in the top and bottom of the mating surface. Some gaskets have the notch cut in them and you can use that for a guide to cut the housing. Don't cut more than you need.
