9.3'' Pontiac rear gear swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2011, 01:24 PM
UngerMarkus's Avatar
TuckīnīRoller
Hi guys!
I want to change my rear gears from 2.56 to 3.42. I think I have everything I need to do this swap including the carrier for higher gears.
I donīt wanna run into trouble or a lot of guesswork during the build, so Iīm asking in advance...
Is there anything to pay special attention for?
thanks
Markus
Old 04-22-2011, 01:44 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Just curious, so you did find the rearend in the '64 wasn't a 8.2" after all? I recall a post you made earlier about this.
Anyway, there were three 'generations' of the 9.3, so I'm guessing the replacement carrier is compatible w/the axles you have, or you got the correct axles.
Fabcraft Metal Works, 800-208-8242 fabcraftmetalworks.com were to have a detailed manual available on the 9.3 but no idea if this actually came to be.
Old 04-22-2011, 02:25 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Ran across some more 9.3 info while looking for Fabcraft info, this is where I saw the 'manual' mentioned- http://www.mydigitalpublication.com/....php?id=171845
Old 04-23-2011, 04:27 AM
TuckīnīRoller
Hi cobalt327!
Yes, it actually is a 9.3'' rear end. At least this is what I was told by Brad from Fabcraft Metal Works.
What Oil would you suggest?
Old 04-23-2011, 01:18 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I use Kendall 80w90 fossil diff lube, but this could change depending on the recommendations of the diff manufacturer. In your 9.3, heavier lube might be preferred.
Additives for the clutch-type LSD using fossil oil is GM additive #1052358 (was a good number, but check to be sure) or Ford Motorsports p/n M-19546-A1 or Spicer p/n 43161. If you use synthetic lube you'll want to check into what to use, although I heard Motorcraft p/n XL3 was good LSD additive w/synthetic diff lube.
Old 05-03-2011, 03:19 PM
TuckīnīRoller
Gear Pattern
Hi guys!
Since itīs my first time installing rear gears, I would apprechiate the pros opinion on my current gear pattern.
Itīs a set from Febcraft Metalworks. According to the markings its from Richmond.
ID:	54967   Click image for larger version
rear end gear pontiac firebird. AndersonRacing44 Transmission - Rearend 7 10-17-2010 11:46 PM
Pontiac rear end swap gene455 Transmission - Rearend 1 03-11-2007 03:39 AM
changing my spedo gear to get right after rear end swap montea Transmission - Rearend 4 10-04-2005 03:33 PM
74 to 65 rear end gear swap? 65_Chevy Transmission - Rearend 4 06-26-2005 01:29 AM
rear end gear swap Jared Engine 3 03-19-2003 08:46 PM
