9" axle gasket" - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2005, 10:08 AM
9" axle gasket"
It's been a while since I tore this rearend appart . (9"ford) What is the location of the axle end gasket ? Is it between the differential housing and the brake back plate? And is there also a gasket between the brake plate and axle mount flange ?
Old 09-17-2005, 02:15 PM
willys36@aol.com's Avatar
Wiki Edits: 21
There is a rubber lip seal behind the bearing that does the sealing. The factory puts a paper gasket between the brake backing plate and the axle flange but I don't know why. It doesn't really seal anything. I never put them in, just go metal-to-metal.
Old 09-17-2005, 03:16 PM
that' all I wanted to know ----------thanks
Axle Information. M&M CUSTOM Transmission - Rearend 1 02-21-2005 01:37 PM
9" Ford Axle seals? kevkoracing Suspension - Brakes - Steering 12 08-20-2003 12:24 PM
axle removal- ford 9" stea Transmission - Rearend 2 04-12-2003 12:07 PM
9" Axle Lengths 68NovaSS Transmission - Rearend 5 02-08-2003 09:00 AM
9" Housing Flange to Axle Flange 68NovaSS Transmission - Rearend 2 10-14-2002 01:32 PM
