9 bolt gm rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2004, 08:55 PM
9 bolt gm rearend
is the 9 bolt the same as the 10 in the chevy camaros
Old 03-21-2004, 12:06 AM
DoubleVision's Avatar
This should be in the transmission rearend forum.
No, there not the same, the 9 bolt is a aussie made unit, 7 5/8 diameter, the 10 bolt is the US made GM 7.5 diameter. The aussie unit is a lot stronger than the 7.5, however, nothing between them interchanges. The Aussie rears started showing up in the Firebird, camaro, blazer, jimmy and S series trucks in 1988 and were used for many more years after.
