9'' brake swap
hey guys, i just aquired a 9" rearend to fit g body. There arent any brakes on this unit although supposedly have f body brake mounts but a 5x5 circle on axles. I have never done a brake swap, so no idea what i should be looking for. I did find some rotor and calipers from 90 firebird that i believe should fit except for bolt pattern, will I be able to find 5x5 rotor that fits an f body caliper? seems like I be better off to drill axles or rotors? Any help appreciated. lost
You have a Ford rear end so why not use Ford brakes. The 5 on 5 bolt pattern is a Ford bolt pattern and they did use disks on some of the larger Ford and Lincolns. I think you'd be better off just heading to the local wrecking yard and looking for a set of caliper brackets for your Ford 9" and then buying a set of Ford calipers and rotors. You can always have the axles and rotors re-drilled for a GM bolt pattern if you want.
Centerline HotRodsAndHemis.com "Speed has never killed anyone, suddenly becoming stationary, that's what gets you." - Jeremy Clarkson |
| Brake swap | Don Lyon | Suspension - Brakes - Steering | 2 | 11-09-2009 12:56 PM |
| 73 to 70 nova brake swap | Gassman | Suspension - Brakes - Steering | 5 | 04-13-2004 02:28 AM |
| 3rd Gen disc brake swap | Camaro2Fast4u | Suspension - Brakes - Steering | 1 | 07-07-2003 05:25 AM |
| Brake Swap | novachad | Suspension - Brakes - Steering | 5 | 02-16-2003 08:04 AM |
| 74 Nova brake swap | CombatWombat | Suspension - Brakes - Steering | 2 | 01-18-2003 01:37 AM |
