9" to chevy conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2003, 06:28 PM
Arrow 9" to chevy conversion
I need to know if anyone can help me with swapping out my stock 12 bolt chevy out of a 71 chevy pickup over to a ford 9" rearend i have been told that all i need to do is cut the brackets off the chevy rearend center the 9" and weld the chevy brackets to the 9" rearend but ive also been warned about setting the write angle on the pinion any help apreciated
Old 02-05-2003, 05:53 AM
Tazz
Cool
Go to Summit or Jegs and order the Brackets. Clean up the 9" and set up the angle and side to side measurments to squair the rearend under the car. Spot weld it in place then come back and weld everything up. Measure, measure, measure then weld! Use a pinion angle tool and remember the TRUCK will need to sit on the rear springs. Try jack stands front and rear and measure the frame height to level. Hope I didn't confuse you.
Todd
Old 10-11-2005, 10:15 PM
knight9481's Avatar
holy crap
im gettin ready to run into the same problem and my brain was spinning after all that... if u can break it down a little better for us kids on the "short bus" id appreciate it...lol. any help appreciated... -Knight
Old 10-11-2005, 10:26 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
For the amount of time, money, and energy you spend. You might want to price out a Moser bolt in housing. All the angles are preset and there is no chance of warping the axle tubes. Then just swap everything into the new housing.
Old 10-11-2005, 10:32 PM
New Member
ahhh
Just an idea I had the other day (really somebody else came up with it)anyway why not leave the ford perches on (just for now) and mach up your new spring perches off those just to get the right angle of the dangle.
I was thinking of doing some thing like that for my rear end it is a ford 9'' set up for a early camaro that will be in a BIG BLOCK 55 Chevy just a thought
