9" disc brake conversion kit ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2008, 03:13 PM
56f100's Avatar
Wow I haven't been here in a long time, well I have a 9" rear end out of a 61 ford truck and I have found what I believe to be a great deal on a complete disk brake kit for a 9" Ford rear with 3/8" flanges, I don't know much about rear ends but my question is how do I tell if I have 3/8" flanges on this early 9" ford, I'm guessing thats the bolt hole diameter on the housing flange?
Thanx guys
Old 06-23-2008, 11:35 AM
327NUT's Avatar
Hey 56.....I'm using a Ford Explorer rear disc brake conversion kit that I bought from Currie's, great deal, has the inner emerg. brake in the rotor hat. This info is directly from their catalog and these measurements are taken looking at the end of the bearing housings.......
small bearing ford...3 5/16" center to center across bolt holes
2" '' '' top to bottom
2.834" bearing diam.
3/8" bolt holes
Late model large
bearing or Torino....3 9/16" center to center across bolt holes
2" " " top to bottom
3.150" bearing diam.
3/8" bolt holes
Hope this helps....Currie (714) 376-2233 for additional info
Old 06-23-2008, 08:57 PM
56f100's Avatar
Right on, thanx 327, I'm going to check it out
Ford Galaxie Disc Brake Conversion CrashFarmer2 Suspension - Brakes - Steering 5 04-10-2010 04:52 PM
1961 Chevy Disc Brake Conversion Kit rock falls Suspension - Brakes - Steering 1 08-22-2007 02:06 PM
Heidt or SSBC Disc Brake Conversion Kits? twborbely Suspension - Brakes - Steering 5 06-27-2007 01:12 PM
Junk Yard Disc Brake Conversion rfowler Suspension - Brakes - Steering 14 02-17-2006 01:04 PM
Disc brake conversion on Ford 9" shockers69 Suspension - Brakes - Steering 1 07-01-2004 10:26 PM
