I have bought a bung ... drilled a 7/8 inch hole and then welded the bung to the housing ... but I would ONLY do this to a empty housing ... not one with the axles and center section still in it. Most places that work on 9 inch Ford housings sells the bungs. |
I had an irritating slow leak from the drain in a FAB-9 housing when I just replaced the lost plug with a pipe plug that would never get tight enough to seal, it wanted to thread clear through; ordered another plug from Alston. Found the plugs are slightly tapered to make a tight, leak free plug.
| Torque converter drain plug 700r4 | blacklabzeke | Transmission - Rearend | 2 | 03-21-2007 08:22 AM |
| drill torque converter and thread a plug to drain completely | murrsue | Transmission - Rearend | 11 | 03-13-2007 06:34 AM |
| Ford 9" oil plug | western star | Transmission - Rearend | 7 | 10-16-2006 08:45 PM |
| Aftermarket Drain Plug | MI2600 | Transmission - Rearend | 12 | 08-15-2006 01:07 PM |
| coolant block drain plug | jwash56 | Hotrodding Basics | 9 | 04-25-2004 03:33 PM |
