Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 08-21-2004, 11:32 PM
68c10owner 68c10owner is offline
9" ford 3rd member strength?
tried a search but came up with nothing. how strong is a stock 3rd member compaired to a nodular one? i have the housing for my 70 chevy p/u but i need a 3rd member. the truck will be bbc powered and hopefully run in the low 12`s high 11`s. the stock 3rd members are easy to find pretty cheap but the nodular ones are getting pretty pricey. i`m planning on running 31 spline axles with a detroit locker. will a stock 3rd member case hold up or should i spend the extra money for the nodular one? thanks.
Old 08-22-2004, 05:48 AM
woodz428's Avatar
woodz428 woodz428 is offline
Arrow re: 9" ford 3rd member strength?
Stock 9" cases are pretty strong, it should hold up fine in a vehicle that will turn the times you indicated. Make sure to inspect it and do regular prep and have the gears properly set up by someone if you are unable to. I've seen some pretty highHP cars running a stock case without any problems. If you start dipping into the mid to low 11s,maybe you might want to consider a nodular case, but I've seen them in the 10s without breakage. Most breakage occurs leaving the line and usually with clutch cars because of the initial shock loading.
Old 08-22-2004, 07:24 AM
willowbilly3's Avatar
willowbilly3 willowbilly3 is offline
Look at the amount of material around the pinion pilot bearing. Due to core shift some stock carriers are weak in that area. If you are running a stout engine and suing slicks or have a heavy car, then at some point the old stock parts will fatigue out and you will get tired of things breaking. If it only gets flogged occasionally you could get by fine.
Old 08-22-2004, 08:47 AM
thanks for the info guys. i think i`m going to hold out for a stronger case since i plan to make the truck faster over time. thanks again,
Anthony
Old 08-22-2004, 10:39 AM
BLOWN 1100 BLOWN 1100 is offline
You can sometimes find them at them at swap meets with gears
for around $350 to $400. Most of the time they come stock with
3.55 gears or that is what the two I bought had.
Old 08-24-2004, 05:59 AM
brainsboy's Avatar
brainsboy brainsboy is offline
brains
I ran a stock ford 9" case in my datsun running 10.70's never had a problem with it.
Ben
Old 10-11-2006, 10:59 AM
alrick427 alrick427 is offline
hi i have one for for sale an spool to.
Old 10-11-2006, 01:36 PM
crankshaftkid's Avatar
crankshaftkid crankshaftkid is offline
Mr 1984
Ben
How much does it weigh? Weight can place a heavy factor in there.....
Old 10-12-2006, 01:06 AM
zipper zipper is offline
9" ford, strength,
i totally agree with crankshaftkid, the weight is the biggest factor plus how hard will you shock it when you leave the line. I have run many stock 9' units and have only lost one when i spit the ring gear out the back leaving 6 neat little holes in the housing.
There are however some upgrades that will make them live. The forst and best is to bottom tap the cap holes and change to as long'deep a stud as you can get in there, the second and almost a must is to put a heavy duty pinion support on the front.
Your truck will for sure weigh over 3,000 lbs. My Nova weighed 3100 lbs. and it ran 10.31 @ 129 and stall converter 5500 rpm, 406"
Zipper
Old 06-12-2007, 08:31 PM
michael golin michael golin is offline
mikeg1055
Hi , just for info , I broke 2 stock housing in my Drag car [ 10 sec camaro ] . it blew the pinion housing out the front of the case . I put a Strange iron center with a heavy duty pinion support and have been running about 10 years since without any problems . Well worth the money [ it destroyed 2 sets of pro gears and a driveshaft plus bearings ].
Old 06-13-2007, 08:45 AM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
I have broken several 9" Ford stock housings. Usually blown the bearing caps off. For the money I like a Dana 60 much better. They are a little heavier but in stock form are much stronger.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
