The 8.5" rears are hard to find and costly when you do. Only came in the Buick GN/GNX/T-Type's, Olds 442/HO's. May be able to get a deal on a 9" Ford rear from one of the Circle track racers or cut & weld the Lower control arm mounts and spring perches from your 7.5" rear. Upper control arm mounts would need to be fabbed for the 9". Also you can get good deals on 9" rears for your G-Body from many Co.'s.
Housing, Housing w/axles and complete rears. http://www.quickperformance.com/Products/housings.htm http://www.quickperformance.com/ads.htm http://www.dcaracing.com/cat_9inrearend_1.html http://www.9inchfactory.com/boltin.shtml |
What If I Got One From A Salvage Yard? Is There A Particular Car Or Truck To Get A Ford 9" Inch Rear That I Could Convert Using My Spring Mounts And Lower Control Mounts? Also Concerning The Upper Control Arms How Good Are Adjustables?
8.8" Swap Info here, Pics are no longer there.>> http://gbodyforum.com/viewtopic.php?p=17067#17067
More swap info. http://www.maliburacing.com/tech_rearend_swaps.html |
I put together my own 9" for my 83 El Camino. The Versailles rear might be a good option if you can find one at a decent price with a gear ratio you want. The other 2 stock rears that are 58" inches are Bronco and 57-9 Ford Wagon.
A cheaper option MIGHT be a wider unit (if you can get one dirt cheap) and using offset wheels which is pretty much what the guys using early 12 bolt rears do. Here is a thread showing what it took to put my 9" together. http://elcaminocentral.com/showthread.php?t=28724 All that being said, even though the 8.5 rears are a bit pricey if the seller knows what he has, unless the one you are looking at is completly junk and needs everything it may still be a bit cheaper in the long run than some of the other options and it will be a bolt in. Last edited by 1957plymouthhemi; 09-10-2009 at 04:39 AM. |
| 1987 cutlass supreme | pena0724 | Introduce Yourself | 2 | 02-22-2009 09:19 PM |
| Buick to Olds cutlass part interchanging | ltrapper | Engine | 8 | 02-08-2006 10:32 PM |
| Cutlass exhaust manifolds | ChrisMiddleron | Engine | 9 | 09-27-2005 03:08 PM |
| Bolting up core support on 71 cutlass. | Wmarden | Body - Exterior | 1 | 12-23-2003 08:25 AM |
| Fit turbo on my cutlass | cutsupreme | Engine | 5 | 09-03-2003 01:58 PM |
