9" ford axle shaft length identity - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2009, 03:07 PM
hey guys
I am trying to save money on axles. Instead of a set of 300 to 400 dollar axles. Don't have a big horse power power plant under the hood. I have access to bar and bearing dumbies to narrow a rear end. And have modified a few. But ordered new axles for the people. I am trying to find out the driver and passenger axle lengths for either a '64 to '65 falcon 9" or '70 thru '77 bronco 9" rear. These are suppose to be 58" wide. Which is what I need for my a model pickup. I have a rear end I can narrow. This way I could get the axle and narrow the housing to to them. Been surfing the internet and have been striking out. Can find all the info needed for complete rear widths. I need more info than that. Any info out there?
Thanks
Old 01-08-2009, 04:17 PM
prostreet6t9's Avatar
Differential/Driveline
Originally Posted by maninacoupe
hey guys
Thanks
66-75 bronco small brg RH 29 5/8
66-75 bronco small brg LH 27 1/4
66-75 bronco large brg LH 26 15/16
66-75 bronco large brg RH 29 5/16
74-75 bronco large brg LH 27 1/4
74-75 bronco large brg RH 29 3/4
76-77 bronco large brg LH 27 1/4
76-77 bronco large brg RH 29 11/16
Old 01-09-2009, 06:17 PM
hey guys
Thanks
Falcons never had 9 inch rears.
Falcon 8 inch rears were 57 1/2 wide same as the 57-59 big Fords, and the 64-66 Mustangs. Mavericks and Granadas through 80.
The 8 inch axles are the same as the 28 spline 9 inch axles, if the overall width is the same. And all those cars had the same 5 on 4 1/2 bolt pattern.
These rear ends have a housing width of 52".
I don't have my book here with me, so I hate to commit, and I have measured a lot and wrote it down,
If you are under 300 hp, I would suggest grabbing a mid 70s Granada 8 inch rear and just bolting the whole thing in. You can probably get a complete unit for $100 or less, ready to drive.
If you get the inclination, the Ford 8.8 is basicly a GM 12 bolt inside, and the Ranger is the correct width. 4x4 rears have 3.73 gears and often posi. easy to get parts.
Old 01-09-2009, 07:04 PM
64-66 Mustang LH 26"
64-66 Mustang RH 30 1/8
66-70 Mustang & Cougar LH 27 1/8
66-70 Mustang & Cougar RH 31 1/4
71-72 Mustang & Cougar LH 27 7/8
71-72 Mustang & Cougar RH 31 7/8
Old 01-10-2009, 05:23 PM
8
Yes 26 and 30 are the correct dimensions for the rear he asked about, and those I outlined in a post above.
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
Splined steering shaft for 40 Ford column heyjude076 Suspension - Brakes - Steering 2 12-01-2006 11:31 AM
Help identifying I-beam axle in 32 Ford heyjude076 Suspension - Brakes - Steering 1 10-11-2006 07:43 AM
Question About 9" Ford Rearend STATUTORY GRAPE Transmission - Rearend 6 07-30-2006 03:31 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
