Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 9" Ford Breather
Old 02-05-2003, 02:46 AM
motionsigns motionsigns is offline
New Member
Post 9" Ford Breather
Just bought a car with a 9" Ford Rearend (Dutchman?) Strange gear carrier, etc. Getting quite a bit of gear oil past the axle seals and suspect it might be due no breather on the rear end... looked all up and down the axle shafts and can't find one. There's a pipe plug on the carrier itself. What do you think of using it and plumbing a line away from the carrier to create a vent. Is there an easier way?
