Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 9" Ford Breather
Old 02-05-2003, 05:14 AM
tm454 tm454 is offline
Tazz
Cool
Contact Dutchman on line and see if they offer a resolve to your problem. If you get into the rearend you may find no axle seals in the axle housing. There should be a seal just inside the housing past the Diff. One on the left and one on the right. This keeps gear oil from running the length of the tubes and out of the bearing. No big deal, drop the drive sheft, remove the axle bolts behind the break plate and slide the axle out. Remove the Diff. bolts and remove the diff. and place the seals in the axle tubes, one on the left and one omn the right of the diff.
Todd
