9" Ford disc brake rear - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2014, 10:30 AM
kleen56's Avatar
I'm using the 85 Cadillac disc calipers on the rear of my Ford 9 inch. I already know these calipers are a pain to adjust and don't work well. I've seen some calipers on ebay that state will fit GM and Mustang II's they look similar to the Cadillac calipers. Anyone have suggestions on replacing the Cadillac calipers with a better caliper? I'd like to keep the ebrake.
Old 07-26-2014, 11:51 AM
327NUT's Avatar
If you have the large Torino type axle bearings you can use the Explorer disc brake set up, probably cheaper than trying to rehash you exsisting Cdillac brakes. The entire kit costs around $400 and has the brackets, rotors with the E brake in the hat and loaded calipers. I got mine from Curries but you can also find them on ebay and a ton of other vendors.
Old 07-26-2014, 12:23 PM
kleen56's Avatar
I do have the large bearing axles, however I already have the conversion kit. I'm looking for the calipers only. I'm just wondering what the GM guys are using since the brackets I have are for the Cadillac calipers. I'm sure there are several who have upgraded without spending big bucks since the Cadillac calipers are in my opinion junk.
Disc brake conversation 9" Ford kleen56 Suspension - Brakes - Steering 9 04-08-2012 11:12 AM
Ford 9" Disc Brake Conversion fredbaker Suspension - Brakes - Steering 18 09-23-2009 03:30 PM
Disc brake brackets for Ford 9" fearsomefairmont Suspension - Brakes - Steering 2 05-11-2006 06:11 PM
Disc brake conversion ford 9" magnum2u Suspension - Brakes - Steering 6 08-30-2004 09:33 PM
Disc brake conversion on Ford 9" shockers69 Suspension - Brakes - Steering 1 07-01-2004 10:26 PM
