9" Ford Drum Brake Problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2012, 10:46 AM
I am in the process of changing the hand brake cables to a Locar set up. However, none of the return spring tools that I have will fit the stud in the upper center on the backing plate and I can't get the springs off. Before I bugger something up improvising, can anyone tell me where I can find the proper tool? Or, how else I can remove these springs?
Thanks
Old 03-30-2012, 10:58 AM
Most brake spring pliers have a cam style tool at the end of one leg of the plier handle. It fits over the lug and you turn it screwdriver style and it cams the spring off the lug. You can buy them separate that look almost like a scrrewdriver pretty cheap. I suggest that because the alternative I've used in my poor days was a pair of vise grips locked to the straight part of the spring and some serious "grunt". It would work but the occasional slip was ugly on the hands. Just looked it up. Lisle part # 46750, about $8 and it will remove and install.
Old 03-30-2012, 01:35 PM
S10xGN's Avatar
Gotta love a turbo!
I don't do that many brake jobs, but this method has always worked for me. Just be as careful as you can and don't get in a hurry...
Russ
Old 03-31-2012, 12:05 PM
Thanks
I was able to get the tool and resolve the problem
12 " drum brake swap strangecars Suspension - Brakes - Steering 5 01-14-2009 05:49 PM
Ford Drum Brake rebuild help! Leaky Pipes Hotrodding Basics 3 08-13-2007 09:34 PM
Ford wide five brake drum question Red 49'er Suspension - Brakes - Steering 1 03-21-2006 04:51 AM
32 ford manual/drum brake cylinder? help! zuppamon Suspension - Brakes - Steering 2 10-27-2004 05:30 PM
Front drum "juice" brakes on a 32 Ford 32Steel Suspension - Brakes - Steering 9 03-03-2004 04:29 PM
