9" ford drum brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2011, 07:58 AM
9" ford drum brakes
on the brake shoes : small shoe in front , large shoe in rear, right.
what if you have large shoes front and back ?
thats what i got from Moser .
Roger
Old 12-11-2011, 08:01 AM
delawarebill's Avatar
shoes backwards
most likely u would'nt notice the diff.. but the lg one does go to the rear.. as the veh brakes the weight moves forward and the rear shoe take the major force....
Old 12-11-2011, 08:05 AM
just wondered if would make any difference in the braking. thanks
thought it might make it a little better .
Roger
Old 12-11-2011, 08:49 AM
Irelands child's Avatar
It could as the smaller shoe does have less contact area plus a good rebuilder will use different composition friction materials, with softer (lighter color, often) being the shorter (most) times. Change them around to correct - it only takes 5 minutes per side once the drums are off.
Old 12-11-2011, 12:45 PM
Wiki Edits: 49
If Moser set it up for you make sure you check the shoes on both sides and measure them. It is entirely possible they put the big shoes on one side and the small ones on the other. Their quality control has gone down hill a lot in the last few years. Had them shorten a pair of 9" axles for me and they didn't even send me back my axles and although they were the correct length, one had the large mounting flange and the other had the small flange. I'll never deal with them again.
Centerline
HotRodsAndHemis.com
Top ten reasons racing is better then sex:
1)You're expected to burn rubber, 2) It's OK to be a spectator, 3) There is a pit crew to help you out, 4) The faster you are the better you are, 5) It can last for several hours, 6) It's acceptable to tailgate, 7) You're supposed to finish first, 8) Earplugs are OK to drown out noise, 9) You don't have to kiss the race car, and 10) You get a trophy when your done.
Old 12-11-2011, 01:43 PM
Quality control, operator integrity and customer care have gone the way of the gooney bird. I put two new axles and brake assemblies on my big 5th wheel travel trailer last fall and this is what Dexter Axle sent me. Both sides of one axle, 8 greasy finger prints on each pair of shoes. After a pointed "discussion" they supplied new brake shoes, but no seals or labor:
Dave W
Separation anxiety - early Ford drum brakes Centerline Suspension - Brakes - Steering 11 03-21-2008 02:35 PM
51 Pontiac "8" drum to disk brakes. Boogie Woogie Suspension - Brakes - Steering 4 05-15-2006 12:19 PM
69 ford drum to disc brakes bigdav Suspension - Brakes - Steering 1 02-04-2006 09:15 PM
Front drum "juice" brakes on a 32 Ford 32Steel Suspension - Brakes - Steering 9 03-03-2004 04:29 PM
8" and 9" drum brakes FAIRLANE DUDE Transmission - Rearend 2 07-09-2003 09:05 PM
