9" Ford Granada Rear End Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2010, 10:40 AM
I have a Versailles/Granada rear end on my '29 sedan. It has disc brakes, etc. I would like to install just plain drum brakes. Anyone have any info on doing this?
Old 03-11-2010, 01:24 PM
big gear head's Avatar
High Performance Rear Ends
That's a change. Most people are looking for those rear ends just because they have disc brakes. You can use drum brakes off of a truck 9 inch. I'm pretty sure that they both have the old type big bearing housing ends on them. Check the bolt size that holds the caliper brackets on. If they are 1/2 inch bolts then the older 9 inch truck brakes will fit.
You will have to press the axle bearings off and install new bearings along with the axle retainers. The disc brake caliper brackets are what hold the axles in now. The will not come off without removing the bearings first. Then you will have to put the drum brake axle retainers on the axles before pressing on new bearings. You can not reuse the bearings. They are not cheap either.
You might want to swap the whole rear end. You could probably sell that one to someone with a first gen Camaro.
Old 03-28-2010, 07:50 PM
Granada rear end
May have what you need . Ineed the code numberstosee if I have a Granada REar end
New end caps on 9" Ford Not A T 25 Transmission - Rearend 6 08-22-2009 04:32 PM
63 ford falcon rear end question bigpoppa3866 Transmission - Rearend 3 03-20-2006 03:04 PM
ford rear end jay1 Introduce Yourself 1 09-18-2004 03:29 AM
Rear End Swap Question Weimer Transmission - Rearend 3 05-20-2003 09:08 AM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 10:50 PM
