9" Ford Guru's, identify please! - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
Old 02-09-2008, 01:01 PM
S10xGN's Avatar
Gotta love a turbo!
Hi Guys!
I stumbled across a 9" rear axle from a truck for a very small price hoping it was a 31 spline, but it's only a 28 spline unit.
Other than that, I cannot identify much else about it. I've been to all the 9" sites and e-mailed "kevinstang" at his site but haven't heard back yet. Here's what I sent him:
I got a deal on an axle the other day, but it's an oddball. The housing is a truck (I think) that has the early style large brg ends, width of 56 3/8" from brg flange to brg flange. It has 28 spline axles, and both axles are 29 7/8" long. Does not have a tag, but appears that it has never been apart with the exception of axle seals.
The case number is C7AW-G. Other markings on the outside of the case are: DIF, 65, and (?) 85. The pinion support shows numbers: C5AW, 4668A, 57, DIF, and 9D23.
The center section seems to be a locker of some type. It has a cast finish on the ring gear side, but 5/8" head recessed bolts. It has one main pin shaft plus the 2 smaller side pin shafts, recessed up underneath the ring gear. Around (and inside) the ring gear bolts are spaced (4) large 0.900 diameter holes which you can see a (circular) parting line where 2 cylindrical objects are mated up. Numbers from the
case are: FOMOCO, and (?) 4268. It also has 2 rollpins showing from the outside.
Thanks for the help!
Russ Selkirk
ID:	27736   Click image for larger version
ID:	27737   Click image for larger version
ID:	27738   Click image for larger version
Quick reply to this message
Old 02-09-2008, 05:44 PM
pmeisel's Avatar
Glad the Jeep is on the road
Last wiki edit: How to identify a Ford V8
Don't have a reference handy, but familiarity with old Ford part numbers tell me:
The "C7" and "C5" prefixes are what you would expect on a late 60s vintage 9 inch...
the two part numbers beginning with "4" are probably the base part numbers for that particular part
I didn't see anything that looked like a ratio or a plant build code in that sequence, except maybe the 9D23, that may have been a build code back in the 60s, but by my time (late 70s--80s--90s) the build codes though similar in structure did not match that.
Old 02-10-2008, 06:41 AM
aka Duke of URL
C5AW 4668-A is the Casting I.D. No of the pinion support. DIF is Dearborn Iron Foundry and 9D23 is the Casting Date Code (pinion support).
To identify the rear (exact ratio), there are stampings on the RG and PG which will require disassembly to see. Without the Assembly I.D. Tag No., you may never know what the assembly is out of.
Old 02-10-2008, 06:58 AM
woodz428's Avatar
Troll Hunter
As greasy as the rearend looks, there should have been a tag under one of the nuts that holds the carrier. That has all the info regarding WHAT and other HOW.
Old 02-10-2008, 07:22 AM
powerrodsmike's Avatar
Wiki Edits: 161
I usually count teeth to find the ratio...it looks like low-mid 3's from the picture. (thin ring gear)
I would think that the 60.75" hub to hub width (29 7/8" x 2 plus 1" or so for the center pin) puts it in the range of a mid size car. Or maybe an f100.( I can't find a hub to hub measurement for one of those...
The wheel bolt pattern can tell a story too, 5 on 4.5 = car, 5 on 5"= bigger car, 5 on 5.5"= truck or van.
The shock mounts look like a truck. ( I know ..you knew that)
Here is a page from the KB with some measurements. It isn't a perfect page, but none of them are.
http://dfwmotorsport.com/Fairlane/9inchrearends.htm
And for those who don't already have the kevinstang page...
http://www.kevinstang.com/Ninecase.htm
If it fits, use it...
Later, mikey
BE different....ACT normal.
Old 02-10-2008, 07:33 AM
I would GUESS a Ford pickup or Bronco. The spring pad mounts are on top of the housing. Cars, as a general rule, have them on the bottom. The width would also be in the correct range for a late 60's pickup. The center section could have been changed sometime in it's life. Most folks ( even Ford techs @ the dealership ) do not always reinstall the the code tags.
I even have a small collection of the tags ... about 50 or 60 of them.
Old 02-11-2008, 01:52 PM
S10xGN's Avatar
Gotta love a turbo!
The guy I got it from had pulled the tag. It came from a truck (year unknown) and is a 3.50 ratio (35 x 10) "Equalok" unit. I don't know when they quit making them, sometime in the mid to late 60's... I don't think the Equalok is worth much with today's better units, but it may show up on e-Bay soon. I'm haggling for a true locker (31 spline) from one of the NASCAR wholesalers right now. This case has the large side bearings (3.06) instead of the normal 2.89.
Russ
Old 02-11-2008, 02:05 PM
streetrodderbn's Avatar
Certifiable Streetrodder
The "equalock" was an early positive traction type clutch setup that utilizes a "belleville" spring to put pressure on the steels and clutches, the down side is that the "belleville" spring would weaken after time, and tended to wear the case and steel it was riding on. The spring was the diameter of the center ring carrier and less than 1/4 in. thick, and unfortunately,not being reproduced as far as I know. I have had a few of these rearends in street cars without problems, but doubt the effectiveness it would have under serious horsepower!
Old 02-12-2008, 08:14 AM
sharpe427's Avatar
C7AW-G = 1967, Full size Ford, Drivetrain group. the 1st letter in Ford PN is decade (B= 1950; C=1960's; D=70's etc..) the 1st number is year in decade; C7=1967; D4=1974, etc.... The next letters are what car line (A=Full size Ford) and who designed it (W=Drivetrain Group) the last letter is a change or use code. Usually irrevelant. This part was designed for 1/2 ton pickups (G) and uses the larger axle bearings (3.063" dia.). Your pinion housing number C5AW 4668-A = 1965 Full size Ford from Drivetrain Group; Pinion support (p/n 4668) changed 1 time (A). The '9D23' is a casting code for quality control. Breaksdown as: 9=1969 D=April 23=23rd Day. So, I would guess that your diff housing is from a 1969/1970 full size, light duty Ford pickup. Usually truck parts have a 'T' code (ie; C7TE-??) but remember the 9" was originally designed for the full size Ford car line, so it carried the 'A' code. Post above is right about the spring perches being the give away for truck heritage. I hope this helps, because I obviously need to get out of the shop more often!
Old 02-13-2008, 09:57 AM
S10xGN's Avatar
Gotta love a turbo!
Great stuff, thanks! This is really good info, would you have a link to your "magic decoder"?
What's your take on the "equa-lok" posi unit, any good? The breakaway torque is pretty low so it prolly could use a rebuild (I've seen kits on E-Bay for it).
Thanks!
Russ
Old 02-13-2008, 06:06 PM
sharpe427's Avatar
I'm sorry, my 'secret decoder' is actually experience and a book of engineering numbers from the 60's that gives a lot of the basic part numbers (like 4668 being a pinion bearing cover). A lot of stuff is on the web, but a lot of it is wrong so find multiple searches and take your best shot! Once you mess with it for a time, it gets easy because the FoMoCo system is very simple and easy to remember.
The Equalok has a pretty good street rep, but doesn't seem to be favored too much on tracks. I think it would be all right as long as you don't intend to hammer it consistently from every stoplight. For constant HD use, I would recc'd a Detroit Locker.
Last edited by sharpe427; 02-13-2008 at 06:08 PM. Reason: Missed question--equalok
Old 02-20-2008, 01:35 PM
S10xGN's Avatar
Gotta love a turbo!
Hey Sharpe!
Sharpe,
Need some more of your I.D. expertise. I bought a used NASCAR (ratchet) locker for my axle, so I got to break down the pumpkin today. For some reason, this center doesn't look like either an Equa-lok or a Traction-lok!
It's got to be a T-lok, the E-lok has 5 lug plates and the T-lok has 4, and this one has 4 lugs. The backside of the case is unmachined (like the open carriers), yet has 5/8" headed recessed bolts (like a T-lok). It also has 4 large through-holes that you can see the small half-moon clips through. The lugs are only on the steels, nothing on the frictions (5 of each). There appears to be no method of loading the plates that I can see, no springs, wave washers, etc. It is a 4 pinion unit. Reckon a T-lok rebuild kit will work?
Thanks!
Russ
ID:	28089   Click image for larger version
ID:	28090   Click image for larger version
Old 02-20-2008, 04:17 PM
sharpe427's Avatar
Look for 4 small springs and pins (about the diameter of an ink pen), they are the loading springs on a traction lock. It is odd though, because the TL should have 4 fiber and 5 steel plates and a machined case!
The EquaLok also had 5/8" headed recessed bolts with the 'as cast'
case, with 3 fiber and 4 steels and a belvedere spring (the wavy one). The Equalok plates will have the 5 'fingers' on the steels.
Both types came with 2 and 4 spider varieties.
Finally; I think you have a EquaLok because of the unmachined case. I think what the previous owner did was eliminate the belvedere spring and replaced it with a stack of fiber/steel to make the diff more like a Detroit Locker. Again, look for the small pins and springs...that is the way to id a TractionLok. I did a surf to try to boost a pic of the pins (no luck) but did come across a site that may help:
www.maliburacing.com
look under the 'Tech' banner, and scroll down to 'Ford 9" '
Old 02-21-2008, 05:00 AM
S10xGN's Avatar
Gotta love a turbo!
Finally; I think you have a EquaLok...
I thought the E-lok's had 5 lug plates and the T-lok's had 4 lugs? This thing has the 4 lug plates. I may have been looking at part #18 as a steel and counting 5 instead of 4. And I think I found the springs, I just haven't gotten into that side of the unit yet. They are inside the pinion block...
Russ
Old 02-21-2008, 06:29 AM
sharpe427's Avatar
If you find the little springs that would settle it as a TLoc, but I have never seen one with a non-machined case...but there is a first for everything!
Closed Thread
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
Ford 9" case storage? 11echo Transmission - Rearend 1 02-11-2004 12:55 PM
Converting Jag rear end to Ford 9" Jag Daddy Transmission - Rearend 5 12-25-2003 02:47 PM
Ford 9" Rear End Narrowing nightrain_rod Transmission - Rearend 3 11-30-2003 11:50 AM
9" ford rearend 37 ford melbishop Transmission - Rearend 3 12-09-2001 09:15 AM
