9" Ford not venting - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2010, 04:27 PM
Aerotech's Avatar
9" Ford not venting
OK guys, I've got a 9" Ford with 3.00 gears on my T and it is not venting but leaking around the fill plug and through the seals as pressure builds up. Pulled the hose and the vent appears to be solidly plugged. No problem, just drill it out, right? Well, the vent plug is VERY hard, the bit breaks off, and of course it's still not venting (except through the seals!) It is too hard to cut or grind off. It does turn with vise grips but does not back out and can not be pulled out. How is this thing installed and how do you replace it?
Old 09-15-2010, 04:33 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I always thought they just screwed out. Hummm!!!!!!
Cole
Old 09-15-2010, 04:43 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
All the one I have done, Just screwed in.. Can you take a picture of it and post it.. Then we can say for sure..
Old 09-15-2010, 04:51 PM
Aerotech's Avatar
It looks like a big pushpin. I'll try to get a shot while it's still light.
Old 09-15-2010, 04:55 PM
It would sure help.. A lot of them had a tee with a hole through it for the vent to hold it to the rear end,, The tee was for the brake lines..
Heres a couple of pictures of some..
The one on the right is the one that goes through the tee..
ID:	48106   Click image for larger version
Old 09-15-2010, 04:59 PM
eloc431962's Avatar
Wiki Edits: 37
Here Aerotech click the link i think this is what you have. http://www.summitracing.com/parts/CUR-CE-9028/?rtype=10 .
Cole
Old 09-15-2010, 05:02 PM
Aerotech's Avatar
Vent photo
Kind of dinged up by attempted grinding, unscrewing, etc. It has proved impossible to remove so far!
Old 09-15-2010, 05:08 PM
Aerotech's Avatar
It is neither of those types. It has no hex nut and does not seem to be threaded. I have tried to pry it out with vise grips attached and it does not budge. It is too hard to break off and can not be moved enough to get a pry bar under it.
It's from a '63 T-Bird if that helps.
Old 09-15-2010, 05:21 PM
I do have to say.. I have never seen one like this.. I would cut it down and pass a light weld over it.. Then redrill another one next to it, and run a tap, and put a new vent.. Put grease on your dill bit, and tap.. This will help to catch the little pieces on metal..
Old 09-15-2010, 05:42 PM
Aerotech's Avatar
Problem solved!
Finally managed to break it off with pry bar under vise grips and it is still firmly in there but with a hole now. I plan to drive a small brass barb fitting in the hole and clamp the hose to the threaded part. Maybe my axle seals won't need replacing after all!
Old 09-15-2010, 06:51 PM
big gear head's Avatar
High Performance Rear Ends
I've never seen one like that. Is there not another vent in the housing anywhere? Is this housing stock or has it been modified?
Chopping a 9" housing 31fordcoupe Transmission - Rearend 7 07-28-2009 06:50 PM
Friction Modifier - Ford 9" motionsigns Transmission - Rearend 10 01-19-2006 12:58 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
9" ford rearend 37 ford melbishop Transmission - Rearend 3 12-09-2001 09:15 AM
