Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 9" ford rear
Thread: 9" ford rear
Old 05-13-2012, 10:36 PM
jmmt1948 jmmt1948 is offline
9" ford rear
Originally Posted by
Is there a seal in the housing, inboard from the wheel bearings. If so the bearings are correct. Just different brands.
Thanks for the response. There was no seal inboard of the bearings. my parts guy sold me seals that will fit inboard on one side but not on the driver-side that has the recessed o ring. the passenger side bearing( the one w/o an O ring was leaking and wiped out the bearing on that side. i am thinking i need to either use the inner seal with out the o ring bearing or change both bearings to the O ring type?
