9" Ford Rear End Identification--NO ID TAG - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2011, 11:06 AM
"Stranded, but not abandoned"
The 9" Ford rear end (10 bolt with rear plate welded in place) in my "54 Chevy truck has no ID tag. The output tubes taper toward the wheels.
These are the numbers stamped on the yoke housing: line one D2SV4L88D... line two 3K2 8 5F3
On the main gear housing these numbers are stamped: 75... 8L2
...and the numbers 16753 form a small circle.
I need to do some repairs and would like to know what I have.
Old 12-27-2011, 11:36 AM
There's not much to be told by the tag. If the rear housing cover is smooth half round, it's an early housing, pre, about 65'- '70. If it has a expanded slot for the ring gear, it's a later housing and considered stronger. All the 3rd members fit all the housings and the only real difference is the material it's made of grey iron or nodular. Carrier bearings are about the same, but some 31 spline axle ones have a bigger bearing than 28 spline axle. On pinion bearings, they are all the same except the datona nodular one which is really rare. On the axle bearing, if it's a ball bearing, they came in two sizes. The big one usually had 7/16 bolts holding the bearing retainer on as opposed to 3/8 on the smaller. The bolt pattern is also different, but I don't have the measurments right now. The other option is a tapered roller and you'll know it when you see it. There's a killer web site on the 9 inch if you google 9 inch ford. It'l tell you more than you ever wanted to know.
ford 9" identification, under the 54 F100 pickup fast68 Transmission - Rearend 2 07-26-2011 12:50 PM
ford 9" identification what does NL stand for 1927tudor Transmission - Rearend 1 03-29-2011 04:35 PM
Ford 9" identification and oil recomended. speedydeedy Transmission - Rearend 4 04-17-2008 12:14 PM
Ford Granada rear end tag identification CrashFarmer2 Transmission - Rearend 22 12-31-2006 05:23 PM
Ford 9" Identification Help tkeahi Transmission - Rearend 6 08-22-2004 06:31 PM
