-   -   9" ford rearend 37 ford (http://www.hotrodders.com/forum/9-ford-rearend-37-ford-8639.html)
melbishop 12-08-2001 04:09 AM
I have a 9" ford rearend for my 37 ford. It measures 59" from where the wheels bolt up. I want to run a standard 3-3/4 back space. Does anyone have the length I need, or do you have a shorter length rearend for sale. Thanks, Mel :rolleyes:
dicks54 12-08-2001 07:31 PM
[quote]Originally posted by melbishop:
<strong>I have a 9" ford rearend for my 37 ford. It measures 59" from where the wheels bolt up. I want to run a standard 3-3/4 back space. Does anyone have the length I need, or do you have a shorter length rearend for sale. Thanks, Mel :rolleyes: </strong><hr></blockquote>
KULTULZ 12-09-2001 04:45 AM
I think you are going to have to go -here- to find what you need.
[ December 09, 2001: Message edited by: KULTULZ ]</p>
Phat 12-09-2001 09:15 AM
Mel you will have to do some measuring thats not something that is allways the same. All and all i beleive you are close with a 59 inch rear. You need to mock it up. What width wheels (and backspace as you say) the tire that your going to use how much room between the fender and tire if you need to mod the inner body a bit. What i think you need to do is do a complete mock up before you go buying another rear. I know most guys want the 59inch and will gladly trade for a 60-61. So go get the tape measure out.Good luck Mel
[ December 09, 2001: Message edited by: Phat ]</p>
