9" ford rearend ID question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2010, 06:05 PM
vettesplus's Avatar
RedRage
can someone id this id tag? i do know it is a 3:00 ratio with a posi but i need to know what year it is and possibly what it came out of. any help would be greatly appreciated.....WFG-1 or l ? -2CB
3L00 9 188A
Old 02-26-2010, 08:45 PM
Originally Posted by vettesplus
WFG
All of the WFG tags I see listed in my Hollander Interchange book are from Ford or Mercury PASS cars 1971/1972 and all are 28 spline units.
Old 02-27-2010, 07:13 AM
big gear head's Avatar
High Performance Rear Ends
That is a 9 inch Ford with a 3.00 gear and Traction Lock (posi) differential. What kind of brackets are on it? What brakes does it have? How wide is it? What is the bolt pattern on the axles?
Old 02-27-2010, 07:25 PM
vettesplus's Avatar
RedRage
posted some pics of it below....
it came out of a limo. it has a coil suspension,large drum brakes,not sure how wide as it is in a machine shop getting narrowed to fit my street rod project. have to cut i down about 6" total to fit. any more info you might have would be great. i want to go get some new shoes and brake cylinder rebuild kits so i am sure they will want to know what it came out of....ed
Old 02-27-2010, 07:36 PM
I'm not very familiar with Ford car chassis, but it could be a '70s T Bird or Cougar.
Old 02-28-2010, 09:17 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
AFA replacement brake parts, you can use casting numbers off the cylinders and drum dimensions to get the right parts,
Have you considered a disc swap? Many '95 up Ford Explorers came with rear discs that will pretty much bolt-on to a big bearing 9".
Old 02-28-2010, 09:52 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
A differential out of a limo , I would have thought a 9-3/8 center section?
Ford vs Chevy question savman1 Engine 31 10-14-2008 08:13 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 06:29 AM
ford rearend in a chevy jo5hi3 Transmission - Rearend 2 12-06-2003 12:11 PM
9 inch Ford Rearend for my 94 Cadillac Fleetwood 94 CADFLTWD Transmission - Rearend 4 11-11-2002 06:33 AM
Ford Rearend 00stang Transmission - Rearend 5 08-25-2002 05:12 AM
