9" front seal replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2010, 05:23 PM
vettesplus's Avatar
RedRage
is there a "how to" thread on how to replace the front seal on my 9" rearend as seen in the pic below? thanks ed
Old 02-28-2010, 05:36 PM
big gear head's Avatar
High Performance Rear Ends
Remove the pinion nut with a 1 1/16 socket and impact wrench. Pull the yoke off and pry out the old seal. Clean the pinion shaft. Clean out the end of the pinion housing and smear a light film of RTV sealant into the housing where the seal will go. Drive in the new seal and smear some grease on the rubber lip. Clean the splines of the yoke and smear some RTV into the splines. Push the yoke back on and put some red Locktite on the threads of the pinion. Use a new pinion nut and torque it to 150 foot pounds. Done.
Old 02-28-2010, 06:04 PM
vettesplus's Avatar
RedRage
thanks for the response and info. next ?? is how do i id what seal i need as i am still trying to id my rearend, have gotten several responses from the id tag. it reads: WFG-1 -2CB
3L00 9 188A
i do know it is a 3:00 ratio posi but i do not know what all the other numbers represent.....ed
Old 02-28-2010, 06:30 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
3L00 9 188A
All i know from looking is the Ford WFG #s came out from 1970 - 1978 ford and Mercury passenger cars, Hope this helps. And if i am not mistaken there are only two size pinion seals so get both if you have to the take the other back. Take the old one with you to the parts house if doing this local anyway. JMO
Cole
Old 02-28-2010, 07:51 PM
prostreet6t9's Avatar
Differential/Driveline
National # 7044NA
Old 03-01-2010, 05:25 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
The old seal should have a number on it too, if it isn't obscured by rust. Definitely take it with you to match it up when you go to get the new seal.
Old 03-01-2010, 11:39 AM
eloc431962's Avatar
Wiki Edits: 37
X2
Cole
Old 03-01-2010, 12:55 PM
That pinion support uses the Nat-7044NA or CR# 18833. Check the yoke for a wear grove where the seal ride's. If there's a grove the Speedy sleeve# is 99181.
Old 03-01-2010, 04:11 PM
After you have the yoke pulled snug, but before you torque it, put some RTV in the cavity formed by the top of the pinion splines and the step on the yoke where the nut contacts, to keep oil from working up the splines and covering the yoke as your appears to have been doing. Dont get the RTV on the threads or the loctite might not work right.
Old 03-01-2010, 04:54 PM
That's why I recommended smearing RTV into the splines of the yoke. If you do this then that will take care of it.
Old 03-01-2010, 05:19 PM
eloc431962's Avatar
Wiki Edits: 37
Right on .
Cole
Front Transmission Seal Popped? BRSleeper2 Transmission - Rearend 3 07-13-2007 05:32 PM
Front main seal question oregon chevelle Engine 2 07-11-2006 05:17 AM
th400 front pump seal question meev182 Transmission - Rearend 6 07-01-2006 08:22 AM
Front pump seal 700r4 KeithB123 Transmission - Rearend 4 09-29-2003 07:19 PM
700R4 front seal KeithB123 Transmission - Rearend 2 09-19-2003 08:44 PM
