9 inch Currie Rear end...I need a YOKE!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2005, 09:50 PM
Hey I hope someone can help me. I have a 2000 ford mustng gt with a 9 inch currie rear end and the driveshaft and the new yoke do not match up. Can anyone direct me in the right direction in where I can buy one? I have contacted currie and they just give me the run around. Please help me so I can get my baby back on the road. Thank you!!
Old 09-14-2005, 09:54 PM
302 Z28's Avatar
Do you have a drive shaft business in your area? If so take a few measurements and they can probably fix you up with one.
Vince
Old 09-15-2005, 07:43 PM
S10xGN's Avatar
Gotta love a turbo!
You really don't want to change the yoke. Buy an adapter U-joint, it's easier, cheaper, and safer (you won't wreck the pinion preload by swapping yokes).
Russ
Old 09-15-2005, 08:43 PM
As a Moderator here.....I would like to
WELCOME YOU HERE.......
I do not know where in South Carolina you are......but The NAPA warehouse is in West Columbia SC on Airport Blvd.
You need a mechanics joint.....it will have the one you need for the 9 inch on one side and the one for the Mustang on the other....
I have one under my 32.....Any Driveshaft place should be able to fix you up.
Again........WELCOME....
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 10:03 AM
38 Dodge rear end dwayne_tn Transmission - Rearend 5 09-09-2005 10:35 PM
dodge challenger in need of rear end advice. Journier Transmission - Rearend 0 05-28-2004 11:23 PM
Rear end identification help 71gtx Transmission - Rearend 1 11-07-2003 08:14 PM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 11:50 PM
