9 inch & Drive Shaft Swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2008, 06:23 PM
Finally found a 9 inch rear for my 67 Mustang with a 289 / C4 it's out of a 69 Cougar, should be a straight bolt in.
Looks like it's been in a sand storm!
Here it is somewhat clean. You can see it's missing a nut on top and there are no washers under the nuts, but it's a 3.25 which is an improvement over my 2.75 8 inch.
Here's the problemwith the Mustang drive shaft, it's a 2 piece drive shaft with rubber in the middle and its got to go.
I'm pretty sure a shaft from a V8 Granada would work just fine after it was shortened to the right length as the Granada has the same C4 and an 8 or 9 inch rear. However there is a 408w in the coupes future and my question is are there any other easy choices for a drive shaft that would be beefier and still bolt right in with my 9 inch and C4 after it's shortened? First thought was a truck drive shaft but they use a slip joint thats built in to the shaft itself.
Full size car with C4 maybe? I think the Mustang uses a 1310 u-joint.
Thanks,
Morgan
Old 06-21-2008, 01:47 PM
First the 69 rear is 2 inches wider, wheel to wheel.
Second, Ford used the rubber 2 piece driveshaft even in the 427 cars.
Adapt to the larger u-joint, using the hybrid 1310/1320 joint, and a shorter yoke if needed and enjoy it as is. But install a drive shaft loop in any hot rod car.
Change the shaft later. You will probably need to make a 3 1/2 or 4 inch thick wall shaft with custom yokes.
Granada 9 inch cars had the bolt together flat flange yoke at the rear same as the Versailles. 8 inch cars had conventional yokes.
I have put 8 inch Granada rears into Versailles cars when getting the disc brake rears out then sold the Versailles.
Old 06-21-2008, 02:30 PM
Re: 9 inch & drive shaft swap
Thanks for the reply, must be a slow day on the board as this post is almost 2 weeks old and no one replied to it till now. Guess no one was interested in my trying to get by on the cheap instead of just getting a custom shaft made. Oh well, I'll figure something out I'm sure.
Still don't want that 2 piece drive shaft.
The Granada 8 inch shaft was what I was thinking. It won't be any stronger but it will be a match I think.
The Cougar 9 inch is the same and will bolt right in.
BTW this is what I have about Mustang rear ends:
1. 1965-1966 Mustang 8 & 9-inch housing width: 52".
2. 1967-1970 Mustang 8 & 9-inch housing width: 54".
3. 1971-1973 Mustang 8 & 9-inch housing width: 56".
4. 1957-1959 Ford big-cars 9-inch housing width: 52".
5. 1960 model T-Bird 9-inch housing width: 52".
6. 1975-1980 Granada/Monarch 8 & 9-inch housing width: 52"
7. 1977-1980 Lincoln Versailles 9-inch housing width: 52"
8. *1957-1972 Ford pickup 9-inch housing width: 56"
9. 1973-1979 Ford pickup 9-inch housing width: 59"
10. 1980-1985 Ford pickup 9-inch housing width:??
11. 1966-1977 Ford Bronco housing width: 52"
Thanks,
Morgan
Drive shaft angle Old timmer Transmission - Rearend 1 09-01-2007 03:12 PM
drive shaft help hotpepper Transmission - Rearend 1 08-21-2007 05:39 PM
will stock drive shaft work with 700r on longbed s10 s10ryder Transmission - Rearend 2 05-23-2007 08:00 PM
Drive Shaft?? APalusky Transmission - Rearend 15 02-08-2007 06:24 AM
Oil pump drive shaft ?? Overdriv Engine 7 12-22-2006 04:46 PM
