9 inch ford to 56 chevrolet - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2006, 10:20 PM
has anyone insalled a 9 inch ford rear end in a tri five chev. I think the distance from backing plate to backing plate is 53 1/4 inches, overall lenth is about 60 inches. I am going to move spring hangers to inside of frame . what I need to know is what year and type of car the 9 inch came out of. I have a 9 inch out of 73 ford 1/2 ton, it has a 300 gear with ford pos track I want to install 373 gear and use the pos track unit all help needed thank you . ray
Old 01-25-2006, 10:41 PM
As one of the moderators here, I would like to..
WELCOME YOU HERE...
I installed a 57 Ford 9 inch under a 55 Chevrolet years ago. It was 2 inches more narrow than the original Chevrolet rear end.
The most accurate way to measure a rear end is this way....
Brake drums vary in width so measuring off the backing plate leaves room for error.
Again ........WELCOME
Deuce..
Old 01-26-2006, 04:33 PM
1st place to go is here:
http://tri-5.chevyrides.com/front_tire.php
I also have a program for rear ends in a tri 5, I just did this last winter in my 57 so im here to help you in any way I can.
heres my car with lots of pics of installing the narrowed 9";
http://www.picturetrail.com/gallery/...6&uid=3413303&
Duke
Old 01-27-2006, 04:19 PM
thanks for the pictures your car is great!!!! I would like your program on installing 9 inch ford thank you Ray
9 inch ford rearend martion Transmission - Rearend 4 01-23-2007 12:08 AM
door latch parts for a 56 ford pu wiseguy50 Body - Exterior 4 01-12-2005 09:38 PM
ford 9 inch or chev 8.5 what should i do tyson Transmission - Rearend 4 08-01-2003 12:11 AM
JAG REAREND INSTALL 56 FORD F-100 Beedog69 Transmission - Rearend 2 07-11-2003 06:46 PM
Ford 9 inch rearend Nos Transmission - Rearend 2 05-21-2003 08:39 AM
