9 inch ford axle question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2012, 12:48 AM
I am trying to find a 271/2" 28 spline ford 9 inch axle for a narrowing project! would anyone know if there were any stock applications that ran the 27 1/2" also needs to have the 3 1/16 center hole for the disc brake rotor set up! it also uses the taper style bearing[ I believe it's considered the large bearing style] any clues anyone?
Old 11-24-2012, 07:42 AM
Banned
I hope you are just measuring it (your needs) wrong..
27" is only a little over 2 feet..
flange to flange most will be 50"+
or is the size you need after you shorten it 27"
Old 11-24-2012, 09:44 AM
big gear head's Avatar
High Performance Rear Ends
There could be an axle that length. As for the bearings, they are interchangable. You can use the sealed ball bearings on an axle that had the tapered rollers. If you go from an axle with the sealed ball bearing to a tapered roller bearing you better be sure to remove the seal from the axle tube or you will burn up the bearing pretty quick.
The easiest thing for you to do is to call Moser and have them make an axle for you exactly the way you need it. You could spens months looking for that exact axle and maybe never find it. A new axle doesn't cost that much. How much is your time worth?
Old 11-24-2012, 10:27 AM
BOBCRMAN@aol.com's Avatar
The best deal is from a seller on Ebay. Axles with 8-10" of spline and you cut them to length. I bought a pair for less than $200.00. Took 6" from one and 4" from the other. Cut with an abrasive chop saw. Look good. Three bolt batterns, well finished. Won't know about strength till next year.
Old 11-24-2012, 11:34 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Sounds good, do they have a warranty? Myself, for $100 bucks more, I would get the Moser alloys with a warranty. I guess if its just a DD that will see no abuse they would be fine. JMHO
Old 11-24-2012, 12:47 PM
9 in Ford axle answer.
Take it from me, call Moser and tell him what you need. Their products are the best and in the long run will save you money. Good Luck.
Ford nine inch axle bearing number shavdog Transmission - Rearend 8 07-14-2011 03:46 PM
ford 9 inch axle spline count torquemonster Transmission - Rearend 15 06-09-2011 09:51 PM
Ford 9 inch outer axle Bearings 55effie Transmission - Rearend 5 06-28-2010 01:31 AM
Ford 9 inch Axle Bearings DRKSIDE Transmission - Rearend 3 06-14-2010 07:07 AM
9 inch Ford rear axle seal kleen56 Transmission - Rearend 8 11-20-2008 08:28 PM
