Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 9 inch ford G body rear axle questions, advantages STD spring, coil over
Old 01-18-2009, 12:33 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
Wouldn't you need the spring perches off the old G-body rear instead of the T-Bird?
Also you'll need a Jig to keep the Housing, Tubes & Ends aligned while welding it all up.
