Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 9 inch ford G body rear axle questions, advantages STD spring, coil over
Old 01-18-2009, 04:18 PM
prostreet6t9's Avatar
prostreet6t9 prostreet6t9 is offline
Differential/Driveline
You can get axles resplined here. http://www.dutchmanms.com/
Keep in mind that they will not add any material to the axles, Some axles are not the same diameter all the down the axle,so you need to measure the axle at the cut point and make sure it has enough diameter.
