Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 9 inch Ford Rear axle bearing
Old 01-19-2013, 12:06 PM
big gear head's Avatar
big gear head big gear head is offline
High Performance Rear Ends
Raise the rear end off the ground and push and pull on the wheel. If you get any movement at all the bearing is bad.
The Following User Says Thank You to big gear head For This Useful Post:
kleen56 (01-19-2013)
