Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 9 inch Ford rear axle seal
Old 11-20-2008, 03:47 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
Originally Posted by kleen56
Correct! I don't need a pinion seal. I need the axle seal at the ends of the differential tubes. Thanks for the info. I thought something wasn't right with the quote. He also mention the seals had to be ordered. I thought it would be a common part and be in stock. Thanks.
Probably has to order because you have the large 3.15 bearing ends. I don't think they're as common as the small ones. I saw some prices for the sealed bearings $28 ea. for small, large bearing & seal $37 @ JustDifferentials
http://www.justdifferentials.com/ind...Path=25_55_337
